1980 70hp terminal wiring for stator and rectifier block on engine
17rogue70
does anyone have a diagram for the terminal block on the side of a 1980 70hp johnson for the stator and rectifier. i believe it was wired wrong when i bought the boat a while back. maybe a picture of the correct wiring sequence. i think i have it right now , but want to make sure before i damage anything.
thanks in advance mike
bktheking
Re: 1980 70hp terminal wiring for stator and rectifier block on engine
Post a pic
17rogue70
see post above
bktheking
Looks good to me, 2 x yellow to yellow and red to red.
Dhadley
The yellows go together, the yellows with grey tacer and the grey go together and the reds go together.
17rogue70
thanks guys ,that means im right.:D you guys are the best
17rogue70
you guys rock ,it was wired wrong. shes charging now:D
