mcurcio1989
Thread starter- Joined
- May 30, 2011
- 40
It is a 80hp 4 cylinder 2 stroke. I finally got this thing running and it ran good for 20 minutes and then developed a misfire. It runs fairly good at idle and will rev up and sounds strong in neutral but under load it has a hard and consistent misfire. It feels like I'm hitting a large rock or something with the prop - the engine even noticeably kicks.
Compression is a consistent 120 on all cylinders. I put an inductive timing light on each one of the wires to check for a consistent spark while operating and nothing looked amiss. I cleaned the carbs just to make sure that something didn't come dislodged and clog up a passage giving a lean misfire-didn't see anything and that didnt help. I tried unplugging and grounding each wire at a time and trying to run with each cylinder dead to see if that would isolate it and that didn't really seem very indicative either. If anything it may have pointed to the 4 cylinder but not strongly. The last thing I did was put an IR gun on each cylinder to see if any were running cooler. It had sat for a bit by the time I grabbed the gun 1, 2, and 3 were at 107?F and 4 was at 99?F so that seems to point to number 4. I'm going to try swapping coils around tonight to see if that temperature pattern will follow that coil. DO any of you have any other ideas? It is just such an aggressive misfire it seems like there should be more of a smoking gun than a slightly cool cylinder.
I kind of want to rule out fuel and timing as the cause as it ran good for twenty minutes and now it is doing this (hot or cold) all the time, without either one of those being changed. To me that sounds like an electrical component that went bad but I don't want to get tunnel vision.
