1980-83 50 hp evinrude
tuna troller
hi all, this is my first post:)
what should the compression be on this engine?
whats the best way to check this.
thanks limit.
tashasdaddy
Re: 1980-83 50 hp evinrude
pull plugs, screw in tester, turn over with key 4 to 5 rotations. record #, then do the other one. 100psi or above withing 10% or each other. i would like to see atleast 125 on both., although, guages differ, the reason the compression is not published. welcome to iboats.
tuna troller
thanks:) compression looks good.
