Gas Giant
- Joined
- Aug 8, 2010
- 239
As with most of the wood in this boat, the transom is soaking wet, so I've decided to replace it.
I've read a lot about replacing transoms on this site, and I have a fairly good idea of the basics. I'm likely going to go with the traditional wood-and-glass route, but a pourable transom compound isn't entirely out of the question.
So my initial question is specific to this boat. As you can see in this pic, I have these two little cubby areas at the rear corners of the transom. One houses the hydraulic steering reservoir and the other the reservoir for the hydraulic trim tabs. They also have space to house batteries:
However, they are both in my way as I need to access the rear of the transom. That little bit of floor sticking out from the transom is also in my way, and is about as solid as a wet sponge. (I apologize for not cleaning up a bit, I was starting to run low on daylight).
I do know that I'll need to remove about 10-12 inches of deck forward of the transom to gain access to work - so would it make sense to remove the cubby areas and the rear floor bit in one big piece? If you guys were doing this transom, where would you make the cut?
Or, if you have other ideas, let's see them. Once I get started, I'll post pics of what's going on, but I will warn you that I'll probably spend quite a bit of time starting at it while drinking beer before I actually make any progress
