1980 evinrude 20hp no start hard to pull over
liftemhi
hay ya'll i'am new here. i have rebuilt snowmachine,s quads, truck engines but not to much on outboards. i trying to help out a friend with his e20crcsa 1980 20hp evinrude outboard. it was running ok, but now its hit and miss. i checked the spark lots of spark, cleaned the carb. compression is 85psi in each. its pulls over real well kicks and then its really hard to pull over . then i removed the plugs and it pulls over fine put them back in and get about 2 or 3 good pulls then you can hardly pull it over again. i put gas in the cylinder and it kicks but wont run some time it back fires. i'am at a loss with it. would anybody have an idea please also there look like something is missing on the head side of the engine just under the recoil (i'll post a pic soon)
tphoyt
Agreed. Did you know if they hit something in the water?
liftemhi
Key checked ok.
liftemhi
Prop turns easy by hand.and turns the motor when in gear.as far as I know they did not hit anything
Have to start somewhere.----Drain inspect gear oil.------Perhaps remove lower unit and see if it is easier to pull over.-----Is the recoil starter properly timed ?-----Yes there is such a thing.
Is the recoil properly timed ?-----Or find an electric start kit ( donor motor ) there are lots around.
