terry32506
Thread starter- Joined
- May 14, 2009
- 31
Hello, I have a 1980 6 gallon fuel tank and hose assy that I am having a problem with and not exactly sure of the part(s) that I will need. The problem I am having is the primer bulb wont stay firm on its own and ultimately the motor dies after a few minutes of running. Having said this if I push the hose connector that connects to the tank connnector on firmer then all is fine and the motor runs continuously without stalling allthough it seems im not getting the full top end speed like I did the first time I took it out for a run which suggests to me that maybe there is some form of an air leak around the connector area and perhaps there is a seal either missing or worn out or maybe an o ring? I have taken this tank out a couple of times this year , the first time the motor ran flawlessly but this second time only a couple of weeks later now having this problem. Is this a common problem with these tanks? I hope I have supplied enough information but if not ask away what you need to know.
Any and all help would be much appreciated.
Thank you.
Thank you.
