1980 Evinrude 90 hp stalls until very warm
keifer855
1980 Evinrude 90 hp Non-VRO. I have cleaned the carbs, replaced fuel pump, Primer bulb, switched gas tanks. Compression 120 all cylinders.
Starts and revs fine with ears. Take it to the lake and put it under even a slight load and dies. This thing just falls on it's face. It acts like it's starving for fuel. Today however I discovered that if I rev it at a higher rpm for for several minutes I can put it in gear and will run great at any speed until I shut it off. Once I shut it off and let it cool for as little as 2-5 minutes than I have to rev the motor in neutral for several minutes and then it will run fine again. The key seems to be the engine temp like maybe the heat is expanding and sealing something. Any ideas would be helpful. Thanks
Daviet
Re: 1980 Evinrude 90 hp stalls until very warm
What's the spark like?
keifer855
spark is good starts easily.
emdsapmgr
It's possible the idle rpm is too low. It should idle at 650-750 rpm when in gear, floating at normal level in the water. If it won't idle at that rpm, you may still have some debris in the idle circuits/passages in the carbs. Cleaning them out requires an aerosol carb cleaner-sprayed through each passage. Remove and inspect each jet.
