1980 evinrude outboard 100 tilt helllllpppp
cabarkeep
could be problems!
I pulled my boat out of the water with engines tilted up (did not put trail lock down arrrgghhhh)... but did not trail with it like that just pulled it out of water ...
when checking trailer/boat/truck ... noted that only one engine was up ... then realized that I had not put the locks down after tilting the engines up ... (dual engines) ... one engine was fine ... the one stuck almost all the way down will not go up or down ...
can hear the tilt motor trying in both directions but no movement whatsoever ...
i cannot seem to see where the manual valve is to at least let the motor rest in the down position all the way ... it is about 3-4 inches from the very bottom ...but will not move ... the other engine was fine ... arrggghh .... any suggestions ???
hellllllppppp :)
JUSTINTIME
Re: 1980 evinrude outboard 100 tilt helllllpppp
sounds like your low on fluid or a check valve is stuck
look around the clamp brackets
#66
