nphilbro
Thread starter- Joined
- Dec 19, 2011
- 304
I acquired a very nice 1980 Glasply 19 1/2 ft runabout OUTBOARD boat hull that has a cracked or broken middle stringer on the starboard side. Up here in the Pacific Northwest these boats are highly valued for their quality, workmanship, and design that is uniquely suited to the unstable waters of the Puget Sound, Straight of Juan de Fuca, and the inside passage. The reason most of us find ourselves on this great body of water is the world class salmon fishing and dungeness crab.
I'm going to document my progress on this thread. I have a 21 foot trailer that also needs some work but proved boatworthy on a 130 mile trip from Mt. Vernon to Puyallup on Christmas eve. I'm going to hang my Johnson 85hp since that is what I have and it should be enough to get the kids going on their innertubes when we take it to the lake and enough horses to manage the Puget Sound.
The seats and carpet were removed when acquired it so it is a straight shot to the hull.
In this pic I have pulled up the panel to expose the gas tank. It is a 50 gallon tank and there is about 45 gallons of gas in it that need to be siphoned out. I fashioned a siphon out of a garden hose, trimmer line, and a rubber gasket. It got too late so I'll run the siphon in the morning. My only access to the fuel is through the top where the fuel gauge is. Don't bother trying to go through the fuel fill link since there is 90 degree bend at the tank.
I estimate the broken stinger is directly below the end of the yellow ruler in this first picture.The fuel gauge is that mess in the center of the tank.
Here's a couple other shots of the boat. I have exactly 1" of clearance in from the back of my garage to the garage door and no motor on. I found that I can move the winch forward and remove the ball receiver and there will be enough clearance with the motor mounted.
Here's shot of the boat in the driveway.
Once I get the gas tank out of there I'm going to start cutting about 2" starboard of the gas compartment and move upward toward the bow about 18" and 18" toward the transom with the spot of that ruler being center point. I't will be interesting to see the condition of the foam.
That's it for now. I've never cut into a fiberglass boat floor before so tips and pointers are appreciated.
I estimate the broken stinger is directly below the end of the yellow ruler in this first picture.The fuel gauge is that mess in the center of the tank.Here's a couple other shots of the boat. I have exactly 1" of clearance in from the back of my garage to the garage door and no motor on. I found that I can move the winch forward and remove the ball receiver and there will be enough clearance with the motor mounted.
