I’ve had a few free evenings to get some work done. I started in the rear and mounted the batteries and battery switch. Finding an accessible spot for the switch close enough to the batteries was my top priority. I ended up mounting it in the rear panel directly inline with the starter. I also made the rear speaker cutouts and reinstalled the panel. With the switch in place I started wiring.
The small fuse panel on the upper right will need to has the power in moved to direct battery power as it powers the bilge pump float switch. From the bus bar I has a 50A midi fuse protecting the #6 wire going to a fuse panel up front.
The amps and front fuse panel are mounted to a piece of 3/4” plywood that is attached to the underside of the bow on the wood supports directly behind where the step/subwoofer will be. This will keep all the wiring up and out of the way and allow me to easily add the interior lighting, USB charge ports and wiring for the stereo and graph. The step has been fitted, sanded and now just needs to be covered with the flooring material, cut out and mount the subwoofer and CD player and install it.
While I was looking at the wiring under the dash I decided I should change the gauges out. It was a simple enough job and the only thing left to do is run the water tube for the speedometer and wire the gauge backlighting to operate only when the navigation lights are on. The original setup had the lights on continuously.
The next job will be replacing the switches. They are still functional but I prefer something a little more modern. If all goes well, I’ll have it on the lake before July.
