Shawnfish80
Thread starter- Joined
- Oct 30, 2020
- 61
You mean run a ground between the solenoid and the block off wich small post?Try jumping the second small post on the solenoid to ground, then attempt to start (post used for the safety switch).
It clicks...if i touch jumper cable to the solenoid post between the starter and solenoid it turns the starter but nothing with the button...14.4 volts on batt.If solenoid clicks the safety switch is good.----Inspect starter.----Get battery load tested.
Safetey switch post...got it, i will try thatYou mean run a ground between the solenoid and the block off wich small post?
And i put a new solenoid on it and now it dont even click...It clicks...if i touch jumper cable to the solenoid post between the starter and solenoid it turns the starter but nothing with the button...14.4 volts on batt.
I get 002 or 003 on the 3/8 posts and a 1 on the left side of screen on multimeter....im getting 14 volts when i test the post that the batt. Connects to on solenoid and use ground on block...it was hooked up like the diagram and all was well....same now but not all is well haha....hmmmmmselenoids are just electrical magnets... aside from the large posts to feed battery +12 the starter the inner coil needs a ground (direct or via safety devices to protect you) and... +12v from the start key position.... so your diagram is OK
if the new selenoid does not "click" it is missing a ground , or... a +12V from the key or the new selenoid inner coil is open ... you can test it for continuity with a ohmmeter and should see a low resistance value . if not it is open...junk
A 1 when i test the 1/2 inch studs on the noid..I get 002 or 003 on the 3/8 posts and a 1 on the left side of screen on multimeter....im getting 14 volts when i test the post that the batt. Connects to on solenoid and use ground on block...it was hooked up like the diagram and all was well....same now but not all is well haha....hmmmmm
