1980 marlin whole deal
jimmy wise
the other thing is on the side of the hull there is a plywood shelf glassed very poorly to the sides. im going to put them back new. are they structual or just for the side panels. also wood how do i know if the boat has a hook made into it? i think it needs to come out when i flip it. it looks pretty deep . do you grind it and build it up to fairing thickness.
v
Woodonglass
I really need to see pics of the the "Hook" Like Zool said it may be natural but maybe not. Get it flipped and post some pics. Don't think the panels are structural.
jimmy wise
im getting there, i have to bring my forklift home. to lift cap off. then brace it. i hope i can flip it with fork lift and cherry picker. uhg
jimmy wise
i cant hold my straight edge and take photos but its up a fat quarter at least. how much does ahull weigh?
Woodonglass
If it's just the hull minus foam, bulkheads and stringers...200 lbs. give or take.
jimmy wise
has the stringers but its not heavy then.....i think it wont be to bad
Woodonglass
My 15 footer with deck and stringers was flipped easily with me and two others.
jimmy wise
this thing is wide...maybe four of us. know one dares answer the phone now lol
Woodonglass
yeah, 4 could do it for sure. Put it on the ground and tip it up and over. Lots easier that way
jimmy wise
well its flipped...no way with four guys to wide and heavy.....fork lift and still no fun. ill try and get photos of possible hook in bottom. she is a wide bottomed girl for sure
jimmy wise
wood, i hate to be a quitter......well i have been offered a deal. 04 cobalt 246 . everything but motor and drive. hull has two holes and scratches from rocks. id rather fix a cobalt. when it arrives ill post photos. much nicer boat and less work
Woodonglass
Uhmmm, don't sound like you're a quitter, sounds more like this...
Us Old Okie Cowboys understand changing Horses (and Boats) as long as it makes Good Horse(Boat) sense. I think in this case it prolly does!!! Get them pics posted soz we can all see what kind of Horse (Boat) Trade you made!!!
jimmy wise
yea, i will. any idea what resin cobalt uses? i know we can fix it . holes are cantalope size. of course they are where the kevlar is.
Woodonglass
Pretty sure they used standard Poly but going back you might wanna consider using VE. It's kinda the best of both worlds.
jimmy wise
No Title
wood picts as promised, complete less , motor and drive no trailer
jimmy wise
no windshields either. so you see the major hull damage.....bottom needs gel coat repairs and some work. everything is with it
jimmy wise
is that mean with the inner hull? yes but there is access to both holes. what do you think
jimmy wise
standard repair? remove foam, grind inner, replace kevlar then two layers of roving inside overlapping, standard outside repair? replace damaged star board or what ever that is that looks like plywood?
how do i make gel coat paste? a lot of scratches on bottom i think filling some with gel coat would be fine. anything faired i will spray and buff in
Woodonglass
I need a better pic of the hull. A cored hull does have plywood sandwiched between two layers of fiberglass. If that's what it is, you'll need to replace it the same way.
