I decided to just start a new post to clean it up a bit and also to resize all my pics.
A little about the boat- It is a 1980 Master Marine "Good Go 28". These were built in New England for Giant Bluefin Tuna fishing. They are a product of Rev Moon. Remember the "Moonies"? Well these are the boats they ran. Who knows how many tuna have bloodied the deck of this boat.
The boats were orignally designed for a single outboard, with most running a 235 OMC. The newer versions offer single or twin outboards, or diesel power.
I purchased the boat on Ebay and I was supposed to be somewhat finished and only needed a little paint and it would be ready for power. I got a really good price and sold the trailer it came with, so basically the hull is free at this point if you consider the price of a new aluminum T-Top. Price was $2600. I sold the trailer for $1000. So basically the other $1600 was the price of the T-Top in my eyes.
Well the boat was in fairly good condition. For the most part the transom was dry and rot free. There were wet areas around the thru hulls and drain. Because of the engine set-in angle, I decided to just replace all the wood inorder to have whole pieces for more strength. The core is going to consist of 3 pieces of 3/4" plywood with 1.5 mat between each layer and then glassed in place using 3 or 4 layers of 1808. Sound good?
The stringers are wet in places, but i have found rot towards the transom. The rot only extends up about an inch from the hull. I am just going to replace them. I will just keep cutting towards the bow until I get to good dry solid wood. While replacing the stringers I am going to install knee braces to connect the upper transom to the stringers.
Here are my plans for the boat:
1) Remove spalshwell completely and completely replace and close in transom. The transom will end up being boxed in basically.
2) Purchase and mount an outboard bracket from Hermco or D&D Marine to mount twin Yamaha SWSII V-76 250HP outboards
3) Remove deck and replace stringers as needed, remove orginal 150 gallon fuel tank and inspect, repostion fuel tank and to allow placement of second 100 gallon fuel tank for a total for 250 gallons. Install new deck
4) Clean up unused holes in console I purchased from Four Sons Marine. It is a walk in console out of a 264 Mako center console. It will end up being cheaper than me modifying my old console considering for $500 it included the hyd steering helm, hoses, and steering wheel, and dual binacle with cables.
5) Build bow pulpit and install electric windlass
6) I may build out the existing bow into more of a point. If I decide to actually do it, I will be asking more questions when the time comes. It would be purely cosmetic and may not be done at all.
Current progress:
The splashwell has been cut out. The deck has been cut out. The top cap over the transom area has been taken off. All wood has been removed from transom and everything has been sanded and is ready for new wood, resin, and fiberglass.
The weather and humidty look good for today, so its time to start glassing.
Well on to the show. Here are the pics to date. Hope you enjoy.
Here she is in the water while i switched trailers
Safety First
Here are a couple before cutting the splashwell
After Cutting Splashwell
More in next post
Current progress:
Safety First
More in next post
