Re: 1980 merc 20hp water pump?
I'm having the same or similar problems with the water pump.
I dropped the lower unit, pulled the waterpump housing, picked all the pieces of the old impeller out, turned it upside down and tapped it with a 2x4 to get any other debris out. installed new impeller, used a small amount of "waterlube" to butter the housing, put it back together.
went to install lower unit, this is where it starts going south....
I noticed the tube on the waterpump housing and the pickup tube are not even a close fit... is this normal???
took it to the lake, no stream out of the water port. Shut it down and took it home...
I dropped the lower unit, checked the impeller it was perfect... I thought maybe a piece of the old impeller may have gotten pushed up into the pickup tube. I used an old fuel line with squeeze bulb and slid it on the fitting on top of the motor to try and backflush the system... no luck there. I slid the hose on the end of the pickup tube where the waterpump attaches and squeezed like hell...
I finally got a little water to come out of the top but most of the water was running back down inside the shaft housing... whats up with that?
I slid a screwdriver into the tube and gave it a few gentle taps to makes sure the tube was seated all the way in and tried again... same results, most of the water runs back down the inside of the shaft housing. anyone got any advice?
