1980 merc. stator wiring
bigdog53
I bought a replacement stator for 1980 merc.The new one has one more wire then original,it is black.I assume it is a ground,but where to hook it?THANKS:D
Laddies
Banned
Re: 1980 merc. stator wiring
Not knowing which engine you have makes that difficult but in most cases it goes to the case mounting bolt on the switch box with the coil ground wires.
j_martin
Under any engine ground screw it will reach.
You're right, grounding through the mounting screws is unreliable.
hope it helps
John
bigdog53
Thanks for the fast replies,very much help:D
