dingbat
- Joined
- Nov 20, 2001
- 17,079
No, that is not normal.I also wanted to point out that while the motor was running (I have clear lines for the fuel lines) I could see tons of bubbles being moved around from the enricher valve to the carbs. Normal?
You have a leak somewhere in the fuel system. Motor will not run as intended until the problem is resolved.
