1980 Sea Nymph SS 165 Rebuild
Status
Not open for further replies.
ezmobee
Re: 1980 Sea Nymph SS 165 Rebuild
I liked the 1/4" Starboard I used for mine. Super easy to work with. You can get white or gray I believe.
BonairII
JMO, but I think you'll tire of a tinted(esp a color other than "smoke") windshield in a hurry. In low light situations, the tinted windshield will further reduce visibility.
jasoutside
Thanks for chippin in fellas:)
K, while the PL is curing, quick update.
To get that transom in I decided to just clip the alum away that will later be hidden by the caps, before...
After, (drilled out those rivets too)...
Then I dropped in my transom for a rough fit, whaaaaaat? Looks like this transom was supposed to be 2" vs. the standard 1.5"...
Back to the lumber yard for another sheet of ply. Rats, I was all set to get that transom all trimmed up and sealed up with epoxy. I can't take too many set backs, my time won't allow for it.:redface:
jasoutside
So, fuel tank to fish box. Check it out. Marked my cut lines...
And hat removal. I used the grinder with a thin cutting wheel for the straightaways and a jig saw for the corner/radius...
Then I drilled out for the drain line...
After that I taped up a pair of plyers and just kinda gently bent down all around the cut out so the fitting will install lower and the fish box will completely drain...
I pitched that black foam ring in favor of 5200 schmeered all over the place. Fitting installed...
Bottom side all gooped up...
This should make for a great fish box!
Piece715
For the dash material i just went with 1/4 plexiglass and painted the backside. It really gives it depth when ya look at it.
Then put a coat of plastidip (that rubberized spray junk; which i think works great for odds and ends) on the painted side to protect the paint from scratching. As for gauges i went with Arctic white tach
boat-analog-tachometer-215106.jpgPretty sure EZ has the same one... it glows red FYI
Buckeyedude
Im liking the fish box alot! I had conteplated doing one of my seat/storage areas that way, but decided to make it big enough to just store a 55qt cooler in it! We put our fish on ice when we catch them down south here;):D
Buckeyedude
Oh, and where i come from (bottom side pic) the bigger the glob, the better the job!:cool:
Decker83
You did an excellent job cutting the tank. I would have thought you may have use another tool to do the job after your accident with your hand.
All of your work looks great. Here's to you making your deadline.
Jon Sob
Master Chief Petty Officer
Great idea on the fish box ...... good job!
jasoutside
Your dash really matches your boat nicely piece. Looks cool with that "depth" sort of feel eh:)
Jas, the fishbox idea is a good one.
Thanks fellas! Yah, I gave a half hearted attempt selling it on craigslist and it didn't go, so, I think this will be a great use for it!:D
Yah Decker, it seems when I run that grinder now something just feels a little different these days. I move a little slower, hold on a little tighter, watch the blade a little closer...:) Side note, I've been trying to gently stretch out that tendon and I am getting closer to making a complete fist with that pinky. So that's good;)
__________________________________
K, goals for today...
- Grab another sheet of ply and laminate the transom to full 2"
- Cut out and epoxy a pair of hatch deck pieces (each side of the fuel tank)
- Get moving on the bow deck cut out
- Install "nailers" to further support the bow deck
- "Think" about how I'd like to rebuild this splaswell
- I should probably order those windshields pretty quick here too, hmmm...
I'll post up some shots of the foamapalooza bow structure later;)
Have a great Friday guys!:D
jasoutside
K, pulled the clamps off and here's what my foam core bulkheads/structure looks like...
You can see on each side of the fish box, really had no value for a hatch so I just tossed in a bunch of small scrap chunks of foam.
You can also see that I stacked up foam around the perimeter of the fuel tank so the sides can help take the load. I left that center section open as I don't want any weight flexing it. Also, double up the deck right there to receive a pedestal base at some point if I want one.
Here's the fish box all laminated in place...
The foam gives it solid structure and will certainly keep the ice cold! I'll come back later and install a gasket all the way around to keep things cool and prevent lopping an arm off reaching in for a soda! I'll also hit all the topside seams with 5200.
You can see the drain line there at the bottom left. I'm pumped there is already a factory drain hole in the hull right there, cool! Since it's going to be inside the hatch there (where gear will be thrown in) I used super heavy duty flexible schedule 40, strong!
I also got these 1.5" "nailers" installed with alum angle and stainless screws, PL on all the mating surfaces...
Those make the bulkheads stronger yet and will give extra support for the deck.
So far so good!:D
dozerII
Jason are you building a fishing boat or a bomb shelter!!!;) Looking real good, lots of planning going on inside that head of yours.
Glen
Piece715
Thanks Jas! The plexi has a backing of some 1/2" ply for strength BTW.... and on a side note I am a Physical Therapist and work with some great hand therapist OTs. Not sure if you're doing any formal rehab therapy but I'd be happy to find some tendon glide handouts and other recommended exercises for ya if needed. Just shoot me a PM... also a paraffin wax bath would be a great investment for that hand... 7 slow dips and then cover with a plastic bag and wrap in a tower and leave it for 15-20 minutes... great deep heat to help with stretching
bear_69cuda
Wow brutha,
You don't mess around... Boat is looking awesome! I do like the jets console and wheel!
peace dood!
jasoutside
Well heck Glen, if nuclear fallout hits MI I still want my walleye slabs and KooAid to be frosty cold;)
Does pumping truck loads of PL adhesive through my contractor size calk gun count?
Hmmm, I've been washing my hands a whole bunch with mineral spirits lately, that's gotta be about the same thing eh??:confused:
Wow brutha,
peace dood!
Thanks man, I gotta keep on it - I see I'm down to only 3 weeks till Sea Trial:eek: Man I got a lot to do:facepalm:
jasoutside
Hey, go some work done on the bow deck.
To scribe it I just laid it on the boat and just traced the starboard gunwale...
Then I shifted it over to the width I needed and traced the port side...
Worked pretty good...
Angled the jigsaw just a bit for a better fit on the hull...
Dry fit: PERFECT! First shot too, like it!
Then I cut the second piece and dry fit...
Not bad, little sanding to get just the right shape.
jasoutside
I really wanted to make this one solid piece so for the bottom side I Gorilla Glued these alum chunks up...
Those were actually cut off the fuel tank turned fish box;)
On the top side I shaped a pair of 3/4" ply pieces and laminated...
I know these don't make any sense right now and look to be a borderline tripping hazard right now but hold tight, they will make total sense when I install this deck;):)
jasoutside
Oh hey, I scored a set of controls too! I really needed to upgrade what I had now that I am swapping in T&T to the Evinrude.
Big thanks to Bob427! He noticed I was needing a set and hooked me up, thanks man!:D
I'll referb these and they should be great;)
Status
