1980 suxuki 9.9 propeller
igotit
I have a project,1980 suzuki 9.9 with an air cooled briggs powerhead.
My original prop aint gonna last forever.
I been trying google.....nothing found.
No longer available
Original props are labeled j700-j900.
Its a 6 spline design.
Anyone know when to get one?
Thanx.
steelespike
What size prop is on there now? Usually under the prop nut./What hp is the briggs?
The briggs will limit top speed at 3600 rpm.
igotit
Prop size is 9 1/4 x8....the splined hub is more important right now,locating a 6 spline seems to be difficult.
Thanx
steelespike
There is a Prop for a DT25 on Ebay Obviously big, but is 6 spline and 10"pitch so may help the the 3600 briggs rpm produce some speed?
igotit
Thanx but a 25 prop wont fit,9.9 shaft smaller diameter and shorter shaft.
steelespike
Won't let me list the site.I did a search for 1980 Suzuki 9.9 prop.
Skipp[ing about 6 eBay listing this next came up.
********** lists a new non thru hub 9.9 prop for $75.
igotit
Ill check it out and see,thru hub or non thru hub doesnt bother me aslong the spline is right.
Thanx
steelespike
A thru hub may fit a non thru hub motor but a non thru hub will only work on a non thru hub motor
Unless it has a dual exhaust like some of the Force motors.
igotit
Im not running my exhaust thru the lower unit,but these old suzuki thru hub props and non thru hub props are completly different designs and will not interchange.
