yt
Thread starter- Joined
- Jul 9, 2009
- 72
Hello, I had a mechanic reseal my lower unit 2 years ago. Fist time I put in afterwards the water pump didn't pump though it tested fine on land. Had to haul it back to him. He claimed corrosion issues.. Then after only a few times in the water it started leaking more lube than before. According to him the shift cover bolts were corroded and couldn't be removed. So I decided to take it on myself. Pulled the lower unit (just love that shift rod screw
) and one of those shift cover bolt heads was sheared off. I was able to get the rest of the bolts out no problem, pulled the cover and simply using vise grips removed the broken bolt. So basically he lied
and didn't do the job right by replacing that shift cover/seal when resealing the lower unit. Probably sheared the bolt head by having his air ratchet set to tighten :mad-new: I ordered the parts but need to know the torque spec for those shift cover bolts and anything else I should know about replacing it. I see theres an o-ring for the shift rod that looks like it goes under the cover. Does that go into the cover somehow or just float on the rod? Also any tips on replacing the water pump. Thanks.
