It still amazes me that every boat project on here seems to have the exact same rotted everything when initially starting. I see yours is no exception either. In fact you could swap those pictures around and it wouldn't even be noticeable. However, once you get all that crappy rot out and grind the surfaces down in prep for the new work to start, it get exciting again! You stated that you did some initial sanding, but you didn't say what you are using to do that sanding. Most everybody uses flapper disks in the 36, 40, 60, 80 grit or something there about in the grit range to accomplish that effort using an angle grinder. And a lot of folks use the cheapo Harbor Freight units as well. So if you don't have an angle grinder, I would certainly invest in one now. Even a pawn shop could yield something worthy. Also make sure you use a coverall type suit to protect your body from much itch and irritation AND certainly a quality respirator to protect your lungs....you may need then later in life! Places like Lowes and such carry 3M respirators and well worth their prices too. Just get the proper filters for the job. I use the vapor type knowing it is much better then mere dust types. I am watching your project because I like bass boat projects... Good effort thus far. :thumb:
