Is there an adjustment somewhere on this linkage? Everything seems to moving where it should, clicks in but won't stay engaged. If you back the gearcase housing nut off 1/2 turn it won't click in at all.
I had it apart and everything looks good, no excessive wear on gears or reverse or forward smaller cogs/gears, pin is clean and not worn, never modified, cross pin is clean no slop in it at all spring is all there and looks fine, shift cam shows signs of shifting but is not worn. The gear is up against the shoulder in the case, the nut is tight but not overtightened. It just seems that when the shift cam pushes the gear back to go into reverse their is not enough travel. I had the lower unit off and the shift cam out, splines seem good, properly lined up and not worn from shifting, no flat spots on the cam or pin.
Someone suggested dropping a small spacer in the pin hole in front of the gear cross pin to move everything that way 1/16 inch?
I don't want to modify anything like that, the thing should work like it was built.
Any advice is greatly appreciated.
SN, is 6476660
SN, is 6476660
