Re: 1981 115hp Rude prop question
Mike,<br /> I too have a Ranger bass boat withe a 115 Johnson . I just bought a back-up prop (Cabelas<br />hi performance 13.5 x 19 ) so I could send in my<br />OMC Raker 13.5 x 20 for some work. I can highly recommend them both. I believe most OMC 115 crossflows will use a 13.5 x 17-19 or 20 prop.<br /> I actually bought the Cabelas prop in a 19 pitch to see if it would help me with hole shot , but have to say the 20 raker is just as good maybe better.The 19 did increase my rpms<br />approx. 100 to 200 but oddly enough its at the midrange operation , WOT is about the same with both props, prop geometry not just pitch has a bearing on this. And what the heck model Ranger do you have that you have a stability problem? Every model I have been around are without a doubt some of the most seaworthy vessels afloat. oh yeah I run about 46 @ 5400 rpm but man I carry some serious weight ,three batteries , tackle and gear to the max etc.
