1981 120 mercruiser rough idle
Dannysmyk
Back again,
Dealing with the ole pig "iron duke" supposedly they don't die maybe I should put this one out of its misery. I've been through it all different problems different days I've had the old girl for 20 years now still holding on. Last season I noticed a shake at idle. It's almost like a miss but it's not. Shakes the whole boat. Yes, carb clean, new electronic ignition, new coil, fuel pump, plugs, plug wires, distributor cap, rotor, all within the last 4 years. It just shakes I don't know hast to be a miss right? Levels out above 1000 rpm and willl get up and go no stalling fires with a flick of the key. Confused.
Dannysmyk
Back again,
Dannysmyk
Here's a video of the exhaust sound. Sorry about the music was jammin. Lol
  • IMG_0430.mov
you have bent push rods in your other thread. your rough idle is because of that.
kenny nunez
With a timing light check that the marks hold steady. I bet that they will not because the bushing above the oil pump is worn out and the rortor shaft is wobbling around.
Scott06
Back again,
not that it matters but the Iron Duke engine is a 151 CID Pontiac engine from the 80's, the marine 2.5 are Chevy based 153 CID engines that debuted in the chevy II in 1962, which was later made into the 3.0 marine and industrial engine.
Good news is if you do need a new engine you could swap in a 3.0 and pick up some horses.
