forty5goingon65
- Joined
- Aug 3, 2009
- 81
my brother inlaw gave me this motor he used it on a zodiac he said it was getting to hard to start so he bought a newer motor first thing i noticed when i put it on the stand and tried to start the motor was it was hard pulling over even with the plugs out so i thought maybe something was tight in the bottom end and so on. i kept working it and finally i got it running water was pumping fine motor ran like a top except there is something missing from the tiller handle to the armature plate because when you let go off the throttle it comes back to far and stalls so i looked it up in the parts section and found out what was missing but back to the main problem with the motor running and me holding the throttle and idle it runs great if i back the throttle of just a little bit almost to stall something really vibrates it all most sounds like a tinging sound so i shut the motor down and started to look for the problem i noticed the armature plate has a lot of play so i took the fly wheel off and noticed the magnets are all scratched up the stator it self is rubbing against the fly wheel that is why the motor is hard pulling over even with the plugs out could someone tell me if i changed the armature plate bearing if that would help my problem thanks
