1981 70 hp tach not working
bowman316
I just installed a tach last year on my rude, and i needed a new rectirier before it would work. It worked fine for a year, but this september it just stopped working. It would jump around, and not move a whole lot. SOmetimes it would reset back to 0 when you turn the key, but then settle back to 2,000 rpms or so, when i know the engine is at 4,000.
Do you think the rectifier could be bad again? or just a wire came loose from the engine? I hooked the tach up from a port comming out of the throttle control box. I jiggled those wires, and not much happened. I have not charged the batteries in months(I have 2), and they start the motor fine. this is a 1981 engine btw.
bowman316
Re: 1981 70 hp tach not working
so i know that the engine is charging the battery's, because i killed both batteries with the troling motor one day. (I'm retarded) and had to pull start my engine. It started right up, and kept running. When I had a bad rectifier, I got a jump start, and it died after it was running. This did not happen this time
bktheking
Check your wiring at the tach and at the rectifier.
R.Johnson
Unplug the tach at the control box. With a volt meter, test between the gray, and black wire at the control box. It should show about 9 volts. Then test the red wire out of the rectifier. Shold be around 14 volt's, or above battery voltage.
