Motor is new to me. Rebuilt the carbs. Have been checking the electronics. I am getting a reading of 0 ohms on the ignitiion coil primary wire, but normal readings on the high tension leads (265 ohms). Manual says .1 plus or minus 0.05 on the primary wire. So could be an issue??? Also, spark does not seem 'strong' on the number one cylinder...
Back to the carbs, with the motor tilted up I got alot of gas spilling out under the cover. This doesn't sound normal to me, or is it?
Thanks.
Steve
Thanks.
Steve
