1981 70hp
dozerII
I picked up a Starcraft with a 1981 70 hp Merc, 3 cyl. The water pump impellor is completly shot no vanes left on it at all. I found 3 1/2 of them in the cavity covered by the water pick-up screens, the rest are just gone. The pump outlet tube is clear. Do I need to look futher for the missing pieces or did they just get ate up?
Glen
bktheking
Re: 1981 70hp
You could try rigging up something to backflush it using the telltale fitting on the block, chances are the vanes are in the block.
aussieflash
Re: 1981 70hp
While leg is off,try flushing through Tstat hole(tstat removed)place bucket under leg to inspect debri.Check tstat and replace gaskets while your at it.
dozerII
Re: 1981 70hp
Thanks for the info I will give it a try.
Glen
Texasmark
Re: 1981 70hp
While you have the tstat out throw it in the trash and get a new one. Don't know if the 81 has an OT horn, but I had a '75 year model OMC 70 hp that didn't. My tstat stuck shut and it cost me a powerhead overhaul.
Mark
