Re: 1981 9.9; Cannot get lower unit off
Put a couple of bolts back in and unbolt it above the LS spacer. The shift-linkage is up there. You'll see a bronze coupler once you split it apart a bit. Remove one screw and the shift-shaft will separate. Then, the whole LU will drop out.
After it drops out, remove the LS spacer and replace the water pump
