1981 Bayliner Victoria 2750 - Restore or Bust
GWPSR
Re: 1981 Bayliner Victoria 2750 - Restore or Bust
I aired-up the fuel tank last night (about 10 PSI) and sprayed the outside all over with soapy water. Only area with any bubbles was around the sender gasket. That's a relief. I will test it again after I clean and lightly sand the outside, in case any grime was plugging a pinhole. I'll prime and paint the outside of the tank before sealing it below the sole to reduce opportunities for oxidation and future pitting.
I'll check the tank again tonight to see if it retained any air. I don't have a gauge to attach to watch the PSI drop rate, but any retention of air will be a good sign.
Hoosmatroos
Woodonglass what is PB?
I'm obviously not WoG but PB is Peanut Butter. Thickened resin that's used as a filler and to smooth out the sharp transitions between wood and poly.
Rebel01
Checkin' in. Can't wait to see the progress...
Cheers!
Tboner7864
I'm still new to this. Sharp transitions between wood and poly. What transitions from wood to Poly? Do you have pictures to show me where PB would be used? Like for the stringers
GWPSR
WoG has a link in his sig that contains his collection of info on bedding stringers and filleting: http://forums.iboats.com/boat-resto...lly-started-w-pics-384982-25.html#post3586813
Several other veteran iBoaters has recipes and recommendations for 'Peanut Butter' (PB) as well. Friscoboater Jay calls it 'Pooky', but regardless of the name, it's thickened resin, using one of a number of thickening agents such as glass baloons, milled silica, or chopped fibers, or combinations depending on the application -- horizontal versus vertical, rock hard versus sandable, thickness needed, etc.
GWPSR
My US Composites order has made it overland all the way to my state! 110 lbs of it. Should be here Monday.
Meanwhile, while it was raining I created a big cardboard template of the area of the transom that will be laminated with plywood. So far it's just an exact copy of the outside of the transom.
Tomorrow I'll trim a half inch off each side and drop it in place and scribe the bottom to more accurately represent what the inside looks like (minimal accommodation for strakes and chines)
Maybe I'll even hit the lumberyard tomorrow for plywood, TiteBond and PL.
T748
Nice template! If I may ask, whats your thoughts on going with the Titebond instead of epoxy? Does the Titebond give a longer work time? -Tom.
GWPSR
Thanks. The Titebond is nice to work with, cleans up with water, is waterproof, and about 1/4 the price of epoxy adhesives or Gorilla Glue. It also came highly recommended by a number of iBoaters.
jigngrub
Thank goodness!
'Bout time some work was done on this bote... there for a while I thought we were going to try to talk this thing together.:laugh:
Looking forward to seeing some wood reinforcement going into this f'glass beast.;)
GWPSR
Today, stuff happened!
I found some beautiful 23/32 BC plywood at Lowes. The C side was nearly clear too, it was straight and flat, and I wasn't able to see any voids anywhere. Score!
A little circular sawing
Some jigsawing
Rounding over the side that goes up against the hull
Cut out the keyhole
And routed out half the thickness around where the thru-hulls exit.
GWPSR
Test fit
Glued
And screwed
Beveled the top edge with the table saw, and sanded all edges smooth
And before ya know it, it's a transom!
Kept gwpjr and I out of trouble for the day. Was going to rig up the clamping bars and all-thread tomorrow, but my hot water heater sprung a leak tonight, and that'll be the first priority tomorrow. Well, and Mother's day too, but unfortunately in that order, if Her Admiral-ness expects to shower. :)
jigngrub
Real work = real progress!
Y'all did a heck of a job on the demo and I 'spect y'all will do the same on the build, looking forward to watching and being part of the peanut gallery.
ShowMeGuy
nice transom work.... Looks like a big arse bayliner..... Would love to have one of these..... Already redone for me just to enjoy! :)
Lwarden
Test fit
Glued
And screwed
So what made you choose the titebond over PL? and are you removing the screws when its dry?
GWPSR
I'll be using PL between the wood and hull, applied to both with a notched trowel, horizontal rows on one, and vertical on the other.
The TiteBond is great between two relatively flat and even surfaces, and goes down really easily with a roller. Yes, the screws are temporary, and will come out before I seal the edges and apply one layer of cloth over the inside surface of the transom. I could have removed the screws today, as it fully cures in 24 hours, but with Mothers' Day, there was no boat time today.
My US Composites order arrives tomorrow. Need to wait for the weather to get out of the 50's before I break out the epoxy.
Probably dabble with making up the clamping bars (2x4's, all-thread, fender washers and nuts) after work a couple of nights.
Looks like Friday is the first reasonable day, with a high of 74 forecast. Maybe use a heat gun to pre-heat the edges of the plywood then to get some penetration of resin into the endgrain.
Either way, it's going to be much more substantial and longer lasting than what Bayliner put in there originally. The original wasn't even sealed. Just painted. And the doubled portion was just in the center.
Tboner7864
Is this two pieces of plywood and you cut and glued them together? What is BC plywood is that marine? What is the thickness of the Transom in total when you finished. By the way looks great
Tbone
gwpjr
Yes, this is two pieces of plywood glued together. BC refers to the surface grade of the plywood. BC indicates that one side is B grade while the other is C grade. See the following explanation of grades for more detail:
Plywood - Wikipedia, the free encyclopedia
We elected not to use marine plywood here because we really don't need an 'A' face on both sides, and we will be expoxying the whole assembly.
Woodonglass
Very nice job on Fabricating the Transom!!! Are you thinking of removing the screws and drilling any Mechanical bonding Holes? Just a thought! I like using em to ensure a good bond and no air bubble between the outer skin and the transom.
GWPSR
Screws, absolutely. Hadn't decided yet about relief holes.
I suppose a few wouldn't hurt any, especially if they are where actual holes will go in the end :)
There are a bunch of holes in the hull that haven't been filled, and they will allow a fair amount of relief too I'm guessing. Looks almost like a cross between swiss cheese and pegboard with all of the things that were screwed to/through the transom over the years. Some holes had been filled by silicone or bathtub caulk, and that has all been removed. Every hole in the transom will be filled when I'm done. Well, 'cept the keyhole that is.
