1981 E70ELCIH - How to change the water intake screen?
mobisware
I have a 1981 E70ELCIH with a broken plastic water intake screen. I removed the lower unit and the water pump but still cannot reach the water intake screen. Do I have to break the seals and remove the drive shaft just to swap out the plastic screen?
Look at your new screen.----See the wee tabs that hold it in place ?----------So break to old screen and remove it.----I think the new screen can be inserted without major surgery.
mobisware
No Title
The screen is a hard brittle plastic. The new one is too wide to slide into place. It looks like the bearing housing is in the way and does not want to budge so far. I'm wondering if there is an alternative or something I'm missing.
????------It is very easy to remove the upper bearing housing.----No damage will occur.---Just 4 bolts and you pry it up and out of the way.
mobisware
Ok. I already removed the 4 bolts holding down the housing. I have not been able to pry it up yet but I'll keep working on it. Maybe some liquid wrench will help.
mobisware
I have been unable to pry up the upper bearing housing. I'm wondering if there is some aftermarket item I can mount to the exterior through the middle water intake hole.
