vidaliaman
Thread starter- Joined
- Aug 24, 2011
- 54
just installed a new switch, black/yellow to raised M, black to M, red to B, yellow/red to S, purple to C, not using A at this time, all 5 wires going to big connector on motor, with switch on off position i can kill the motor by clipping wire onto ground on battery and touching black/yellow wire on motor side of big connector. this switch shows one of the M's needs to go directly to ground, however one wiring diagram shows that M going to the motor going through big connector, another wiring diagram shows black wire coming to switch goes to ground then another wire going from ground to M, where maybe a kill switch can be added from ground to kill switch to other M...
another note, the switch starting from B at 6:00 o'clock clockwise goes M, I, C(middle), A, M, B.... this is not what was on the directions for this switch, the direction say starting from B clockwise M, C, I, S, M, B
seems like i should be able to run a wire from the battery ground to the switch(ground)
sorry about the rambling, my brain is fried by overthinking this, what am i missing, the answer is going to be easy but i have brain fry
thanks dave
gowen mi
thanks dave
gowen mi
