1981 Evinrude 60HP
alexkbee
i just bought this boat fairly cheap everything is hooked up as in the steering wheel but the throttle isn't does anybody have a pic to show me where on the motor i'm supose to hook this on to i just had a quick look an seen a long rod at the end of the cable to where the motor is supose to be hooked up but didn't see where on the motor the other end goes to any help?
alexkbee
Re: 1981 Evinrude 60HP
also can somebody tell me what sparkplugs an what to set them at i guess the guy took out the plugs an never put them back model# E60ELCIA
tashasdaddy
Champion QL77JC4, other brands are known to cause misfires.
alexkbee
thx ok so i fired up the engine took for a spin in the lake i'm having a lil problem i'll open it up an goes fast then slows down then picks up fast again back down to slow then dies out i'll start the engine back up same thing cleaned both carbs spotless any idea's ??
alexkbee
nevermind i fixed the problem..was the connection to the gas line was no good on the engine an my prime bulb was always soft so i replaced the connection plugin part all is good now..thx anyways ;)
alexkbee
having trouble here...missing throttle control cable nut on both forward an reverse on the motor :confused:
alexkbee
i fix this problem by buying small nuts with a plastic insert an they are holding quit well :)
