Bannister 6905
Thread starter- Joined
- Jun 5, 2015
- 110
OK, so the tach issue was a loose connection at the control - here comes the next opportunity...
Verified with a timing light, I am getting random "no spark" when the engine is cold. Sometimes, #1 and #2 are dead. Other times, #5 and/or #6 are dead. This is running on the hose, both at idle and and 1500rpm. #3 and #4 are always firing.
However, after warming up, all cylinders are getting fire and the motor runs great.
On the water, I get that misfire again when cold, but after warming up, the motor runs well -
Compression measured 140+/- 5 psi; carbs rebuilt, new battery, new water pump (strong stream from discharge), new NGK plugs, timing set and carbs synched...FYI only.
I am looking for experienced opinions as to where to look next...appreciate your input.
Bannister
Bannister
