I have a 1981 Mark Twain 16' V-Hull Ski boat, it has a 140 hp mercrusier. I have just got it running its been sitting for about three years, the engine starts fine and runs and sounds good. But the problem is that is has a bad water leak, if you are in the boat looking at the engine the water is leaking from the left side on the back of the engine just behind the starter. I have been running the engine on muffs in the driveway and the water is comming out with a good bit of pressure. I have read some posts concernig simmilar problems and seems that they were talking about the shift bellows and the drive and exaust bellows. Does this sound like the same problem or is it somethig else?
