1981 mercury lower unit ?
Chris1956
Re: 1981 mercury lower unit ?
If it is truely gear oil, supect that the driveshaft seal in the base of the waterpump is leaking, or the waterpump base oring or gasket are leaking. Replace the waterpump base, wear plate and impeller and gaskets. Clean the driveshaft and lube it before installing new base, or you will tear the new seal.
mavmike72
Thanks for the reply . I did put a water pump on last year but nothing else . Should I buy a hole seal kit ? Where is the best place to purchase it ? Thanks alot
Chris1956
Just replace driveshaft seal kit for now. propshaft seal is a bear to replace.
BTW - verify your motor's year via serial number. I thought 1979 was the last year for the Merc 140HP IL6. You will want the right parts.
mavmike72
Tag on transom is 5741787 can you tell year off this number ?
Faztbullet
If you motor has the speedo pick up cast into nose of lower unit I would pressure test it first as the only 3 ways gear oil could come thru the speedo hole: 1) someone drilled it out to clean debris and went to deep 2) shift shaft leaking and speedo connector is removed 3)speedo passage stopped up and froze causing crack in housing.
mavmike72
After looking at it again its not leaking from the speedo hole . It's leaking from another hole up higher . Rite where the lower and upper meat . This hole is on one side only . I also have a longer transom saver on it too . U think I had the motor up to high making it leak ?
mavmike72
I lowered the motor last night and this morning it was dry as a bone under it .
carholme
If the oil was enough to leak out of the drain hole, either the shift shaft seal or the seals under the water pump have failed. If and when you run the engine again, make sure you check for the same leakage after you run it. And it would be wise to see how much you have lost before running it again. It would be bone dry if the freeze cavity emptied, it is just waiting for another load when you run it.
Gerry
mavmike72
Is their anyway I can pressure test it myself ? Thanks for the help guys .
Chris1956
Are you positive it is gear oil? 2 cycle motors leak 2 cycle oil out of there routinely.
MH Hawker
I would sure run a pressure test first, because a lot of 2 strokes do leak a bit of un burt 2 stroke oil out.
Chris1956
Crap, just smell the leaking fluid. If it stinks like rotten eggs it is gear oil. If it smells like gas or oil, it is 2 cycle motor oil.
