1981 mercury thonderbolt 40 hp
info404
ok, so, for the last couple of trips, i had a problem starting my motor, i thought it was moisture getting into the engine from the drive to the lake. after about a 1/2 hour or so it would start and be fine all day. i really didn't worry about that. when i get home i always clean my plugs and fill with fresh gas, 50-1 ratio. the only thing i did different this time was add some marine stabil. it started fine on the water, but i had no power. it felt like it was running on one piston. i changed the plugs and again no power. when i throttled up it went fine then when i hit the throttle all the way it sort of lugged and felt like it was chokeing a bit, but kept running. i'm hopeing its a bad coil. i didn't check to see if it sparks yet and figured maybe one of you experts recognize the symptoms. i didn't have any problems with the carb. it just didn't power up to full power. any ideas?? thx to all takers in advance..04
achris
More fish than mountain goat
Re: 1981 mercury thonderbolt 40 hp
Compression test and new plugs.... See what that does..
info404
achris, thx for the speedy answer. i checked the compresstion and its 120 on top and 120 on the bottom, with new plugs. could it be electrical? whats a good way to check for sparks without a guage, (crank in the dark?)
Faztbullet
Download the CDI trobleshooting manual and test you ignition system...
