I bought some PVA but ended up not liking it. It's difficult to see once applied and dried and then how do you know you've got it all off? I'm sure it has its place, but I much prefer just adding wax to the last layer of glass/gelcoat.
If you use laminating resin (no wax) and don't use PVA or something else to seal it off, it will still solidify rock hard...the surface will just be tacky (especially after an acetone wipe) and ready for the next layup. I do not recommend you add wax or coat in PVA until it's your absolute last layer, and I wouldn't do either if it's an area that will be hidden below the decks (like the stringers where you are going to fill the areas with foam).
