Finally back at it, brought the boat down to the shop today and got it hooked up with the A frame and forklift, lifted it off the trailer and got that out of the way, then slowly raised the one chain fall while lowering the other to get it rotated 90°. Had to really guide it past halfway but once it started it was fairly easy and did the reverse with the chain falls. Got it set up on some wood in a comfortable position to sand the existing paint. I first gave it a wash with only water to rinse any dirt off, then I sprayed degreaser on it and using a brush I scrubbed a lot of other grease and grime off, with another rinse and then let it air dry for a few hours. Began feathering out all the chipped paint spots first, wasn’t too difficult with the different tools I had. Sanding near the rivets was rather tough so I used a pneumatic die grinder tool with stainless wire wheel to clean the areas around rivets. Once I get everything feathered I’m going to do a final sanding over everything and then scotch brite and then a degrease and use acetone before spraying primer.
