1981 Starcraft Super Sport 180 - Gonna try a Restore
Candutch
Hey all. Does anybody have an idea of what length the wiper blade and arm are? I have an order to put in for parts but don't want to do it incase the wiper blade, 11", and arm, 8.5 to 12", that I selected won't work.
Any help would be much appreciated.
Grandad
I don't know for sure, but I don't think there was an Starcraft OEM wiper. I think they're all add-ons, so each might be a custom fit depending upon the the motor placement and size of windshield. Mine had 2 defunct wipers when I got it, with the placement just off-center of each pane, but some might prefer the motor to sit in the corner. - Grandad
Candutch
Thanks Grandad. Mine is mounted in the middle and it is quite the hack job, leading me to believe you are right about it not being OEM.
Candutch
Made some decent progress this weekend. Got all my vinyl cut for the decks, gunnels, side wall and console. Still too cold to put it down though. Made some rod holders out of black hdpe to augment the two store bought ones, cut the three hatch covers and the console fronts and filled all of the countersunk rivets with epoxy. wood filler. I also started sanding the exterior so I'm ready to paint when it's warm out.
View attachment y4m9ByxMPSlidyGgD-oOoYTzWHHn8Y2lSHzsihSIuCmfaScYQepZYhDt7cjdBCT8KRBN-795DBFEN8Tsrhxdp23YuqffPlc23yNU
View attachment y4mS9ml6hyWgKNZUc1krt0JkSAHua117X1rRjydKzjTs5ssYmf-k9oIyx1rrkh-vdP1rqq3f6kqOabOTlWYZL6pukSU2f5Sj61q2
View attachment y4mCgVsp_sgDpJdfT3p7GjRNtxSf7Rd2jq1StKCV6SgZxOBD9SllGCm3XaOV_VtqojlCAVXkEDHrWcA8BdRBG2hxoj30evrvpRcL
View attachment y4mu7JIBfrYbj5fXX0jp1lRrAIUCt1PQ35PcciB-LnHZRL1nGvdU92ZPHub9yNZSC9Phh3gq3Segxd68fn-jL12rBUKcsiAk5MAH
oldhaven
Good indoor progress being made there. Waiting for sealer, filler and paint suitable temperatures is frustrating and contributes to a lot of clutter in the inside work area at the end of winter as the indoor projects accumulate. I will be so glad to put things back on and in my boat which is outside now, and I bet you will be happy to get yours out of the shop and into some sunshine. Everything looks great.
Ron
classiccat
Excellent use of space there Canduch; You've got the room of a 22 footer!
I think my 8-foot, 1-piece pool-cues with Penn320's would be right at home in those rod racks :cool:
It's really coming together!
Watermann
Great layout and use of available space, it's nice having 18' to work with. Will be looking forward to the upcoming finishing touches. :encouragement:
Candutch
Ron
Thanks Ron, I spent at least an hour moving crap around today so I could get at the sides to sand. I can't wait to start getting stuff back into the boat. It's supposed to be 19 degrees celsius this Saturday but of course I'm working.
Candutch
Thanks CC, the port side will hold my 9 foot salmon/ steelhead rods. The starboard side will only hold 7 footers because of the control cables and wiring.
Candutch
Thanks Water, I really like the room on the 18. Looking forward to seeing what you have in store for that v5 of yours.
dozerII
Great progress Rob, I like the rod holder made from hdpe, are you just using the poly cutting boards that Crappy Tire puts on for $3. a piece?
Candutch
Thanks Glen, I almost did buy a cutting board at crappy tire but it wasn't on sale and wasnt thick or long enough. I actually bought a 1' x 2' x 1/2" cut off piece at an industrial plastics place. It feels a little harder than the cutting board plastic, more like the starboard rod holders I bought.
Grandad
Ya, I found cutting boards are a good source for more than just plastics. I made these steps from solid bamboo hardwood cutting boards that match the trim in my boat. - Grandad
Candutch
Those look fantastic Grandad! It sure is a lot more satisfying when you re-purpose stuff.
Being my last day off I decided to take on a fun project on the boat instead of sanding and feathering paint. Built my tackle box tray today. It took a lot longer than I thought (5 hours) but I'm really happy with how it turned out and compared to a store bought one it cost peanuts.
View attachment y4mJuMmqr4DXKeIRFeuqipztLglA6NsPT28ijztUh28MjBhLPBSkVBYxmzUFaAR2EsYPn6S8Y04ItVorfGTDhNIT8BDx1_S3hii3
Here it is in its home
View attachment y4mwuUK7DY0jFhoOupZO8pZRc7aEZRuhiasjZ0jlrUgt4u2H6jX-d5toQhxVbNkz62lLMfRVo1jbdFWPn-jtdKgQPNWmo4f-ou4r
Now I need a some more Plano trays.
PikeHunter431
You've got some great metal fabricating skills Candutch. What do you use to cut the aluminum angle and sheet?
I really like the rear deck design and how you raised the sides of the transom.
Candutch
Thanks Pike. To cut the angle I just got a 7" metal abrasive saw blade for my mitre saw, it's a little slow and you have to file off the rough edge but it works fine. To cut the sheet I just used a metal cutting blade on my jig saw and cutting lube for the thick stuff.
This is my first attempt at working with metal and it wasn't too tough. Just remember, measure twice and cut once, slow and steady wins the race.
Grandad
I've always used the same carbide blade for aluminum as I use for wood in my tablesaw. Go easy and wear eye and ear protection. - Grandad
Decker83
I have used the same carbide tip blade in my mitre saw as well..
Your work is awesome..
Candutch
I have before as well but I only have my good one for hardwoods right now and I don't want to wreck it. This blade was 10 bucks vs 30 for another carbide tip.
