I hammered out the bent up transom and it is looking nice and flat again but I noticed a crack on the transom aluminum right between the upper and lower attachment areas of the knee brace. Can't tell if it is all the way through as it is right under the rail that holds the bottom of the transom wood. I cleaned it up and covered it in JB Weld. My plan is to cover that area with 1/8" aluminum checker plate, 5200 and bolted through the hull where rivets and other fasteners are already. Does anyone foresee a potential problem with this plan?
I also noted that most of the transom rot was where the splashwell attached to it, probably why there was 2 inches of caulking along there. The way it is designed I can't help but think that this will be the weak point again. I was thinking of skinning the inside of the transom with a thin sheet of aluminum and having the rail that the screws go through inverted and extend 3 inches so the drain holes go through it. This way the water will be contained by the lip extending up wards and not sitting on the seam. Does this make sense?
The cracks on the other side of the splash well look the same as pictured. The screw flange also has a couple of chunks broken off. Good advice to remove the z bracket, that will be my next job. Can I put it back on with stainless steel machine bolt and nylock nuts? I'm not sure I want to tackle rebucking rivets.
