1982 7.5hp impeller change
oldcatamount
Hi Guys, Can someone guide me as to how to remove the lower unit from this 1982 7.5 hp so that I can change the impeller. Any help will be greatly appreciated!:confused:
e10
Re: 1982 7.5hp impeller change
What make motor and what year?
oldcatamount
It's a Mercury. I also need the spark plug number.
The Mechanic
Remove nut (9/16" wrench) below cav plate, forward side of gearcase.
Remove nut (1/2" wrench) above prop next to inlet screen.
Lower gearcase should separate.
Spark Plug = Champion L77JC4 (above serial number 5226934).
