1982 70hp evinrude low speed adjustment ?All the way in then what ?
johnmark
I have a 1982 70hp evinrude cleaned carb.s need to know the low speed needle adjustment. thanks,John Mark
johnmark
Re: 1982 70hp evinrude low speed adjustment ?All the way in then what ?
Still need help Please
mark1961
Ensign
Are you referring to the idle passage above the carb intake?......it has an orifice, washer and plug like the rest of the carb circuits so non adjustable unless you start experimenting with orifice sizes and you really dont want to do that......im assuming youre not at elevation?
johnmark
this one has a needle in each carb for the low speed. last year i think .thanks
mark1961
Ensign
I must be missing something.....the '82 carbs were the non adjustable......it was the last year of those.....'83 on had needles above the carb intakes, the static setting on those is lightly seated then out 1 1/4 turns, you will have to fine tune running in the lake tied to the dock......what is the model number of your motor?
johnmark
it is E70ELCNB MAYBE SOMEONE SWAPPED CARBS DONT KNOW DOES HAVE LOW SPEED NEEDLES , THANKS
mark1961
Ensign
That must be the case......I have answered your question in my previous post.....
johnmark
YES THATS ABOUT WHERE I SET THEM SHE RUNS NICE NOW, WAS NO FIRE ON THE BOTTOM CYL. POWER PACK FIXED THAT THANKS FOR THE HELP HAPPY BOATING,John Mark
