The outboard is running fine, shifting through gears, but it blows a constant white smoke from the lower unit prop area. Is this a major concern? What is the best fuel mixture for this engine?
50:1 mix. Its suposed to blow smoke thru prop. If its blowing a lot of smoke Idd do a decarb on it.<br /><br />FAQ'S will tell you how to.<br /><br />Good luck!
Thanks, i will also need to find a better set of controls. The ones that came with it are not figured for a center consol. Any advise on that or where to find them?
