1982 90 HP Mercury Inline 6 cyliner 2 stroke carb issues...
craignorton
Hi y'all. Having some problems with my carbs. Floats seem to be sticking and flooding my 1 and 3 carbs. I have pulled the tops off of each and when I immerse the float in the gas in the bowl they both rise, so the floats seem to be fine. The valves in each toggle easily up and down on each, and there appears to be no drag on the levers that toggle the needle valve. I pull the tops off of each, reassemble and the unit fires right up. Run around the lake for a bit and when I slow down to a near idle and check the carbs fuel runs out the two of them. And then of course it's flooded. I'm thinking that the float chambers maybe need to be cleaned in case the floats are sticking on the sides. Also, the springs on top of the floats seem OK. Need some advice so I can run this ol' girl like it meant to be run, any ideas?
angelr2lt
Re: 1982 90 HP Mercury Inline 6 cyliner 2 stroke carb issues...
craig,
Did you find a solution to your problem. I have same outboard same problem, but my its only having fuel coming out the top carb. I pay to have it clean up it was running good for a while, but them began draining my fuel tank again, angelr2lt@yahoo.com
CharlieB
Which style floats, cork or newer plastic?
Older cork had a tendency to absorb fuel and not 'float' as high as the newer plastic ones.
Chris1956
Honorary Supreme Mariner
Merc had foam floats and hard plastic floats. The foam floats used to disolve after a while. The hard plastic ones can crack and sink. I recommend you inspect them and make sure the inlet needle and seats are good. Also make sure the little spring on top of the float is good.
