1982 Chrysler 105HP spark plugs
Frank Acampora
Re: 1982 Chrysler 105HP spark plugs
Years later when Mercury started making Force engines which are the exact same block, they changed to L76V Which was always a Mercury plug.
So, the choice is yours L20V was the Chrysler plug but L76V won't hurt the engine.
devl
Is there an alternative that doesn't use surface gap plugs?
Frank Acampora
NO! Some people recommend a bent electrode plug for a better idle but if you use a bent electrode plug you are running the risk of melting holes on the pistons.
You can use NGK BUHX if you don't like Champions and Autolite also makes an equivalent but I forget the number. Incidentally, Champion changed the numbers on L20V It is now called something like a 322 I haven't bought one in years so don't call that number gospel.
devl
Thanks for the info! Ill stick with the original.
