geneseo1911
Thread starter- Joined
- Jul 3, 2011
- 183
Well, I'm back to working on the old brown Cobalt. I have been chasing a persistent water leak since I bought it, and convinced myself that it was the exhaust system. Fixing it meant pulling the engine.
The old Merc 260 has a three-piece ram's-horn whatchamacallit, and sure enough, the port side had two loose bolts and was almost certainly leaking.
When I pressure washed the bilge, I discovered the inevitable....a 30 year old boat with a rotten transom. In Cobalt's defense, it was not too bad, and was obviously caused by a sloppy transducer installation at some point in the boat's life. That certainly explains the stress cracks.
A little more exploratory surgery revealed the extent of the damage...floor good, main stringers good (phew) foam dry (PHEW!!!), motor mounts good, but the little stringers in the bilge were gone, the fuel tank support (and the little piece of ply that supported it) was gone (this piece was only 1/4 ply and the ONLY unencapsulated piece of wood in the boat).
I'm making good progress. I got all the drive parts out in one weekend, and got all the old wood stripped out in one weekend and two evening. My glass & supplies will be here Tuesday, the Arauco ply, pink foamboard for patterns, and PL Premium were purchased at Menard's yesterday. I hope to get the grinding done tomorrow, and the new transom and stringers laminated Sunday. In addition to that work, I plan to build pyramids for the front seat pedestals so I can have a little better visibility, and seal up all deck penetrations to make sure I never have to do this job again. The deck has pulled away from the starboard stringer, so I will re-tab that back together as well.
All in all I'm impressed with the Cobalt's build quality compared to some other boats I've seen here. They individually encapsulated each piece of wood, which obviously saved the main stringers from the rot spreading into them. This is actually turning out to be a relatively easy project.
