nphilbro
Thread starter- Joined
- Dec 19, 2011
- 304
OK, so I'm a bit stumped here. I was working on this motor a guy wants running to sell and at first it would crank over as I checked spark and compression on each cylinder (which were fine). I pumped fuel into the carbs and the starter slowed, then wouldn't engage. I took the starter to the rebuilder and it was burned out.
I pulled the solenoid to clean the poles and I put a new starter on, wired it back up so I could get the motor back into shape, turned the key - nothing. Perhaps this Chinese starter was bad out of the box? Ok, pick up the rebuilt starter, installed it - nothing!
I messed with it for a while, checked and traced the wiring from the diagrams, and then realized what I thought was just an aftermarket solenoid was more than that - it was from an auto shop! While I was trying to get the mounting holes to line up (which wasn't going to happen) I recalled that all the other solenoids had a strap with a dielectric rubber sleeve to isolate the ground from the housing.
This solenoid's mounting bracket was connected directly to the back of the solenoid - grounding it directly to the block. It still had 4 poles but there was nothing I could do to make it work. It must have been wired differently before I removed it so when I put it back on - correctly (by OMC wiring diagram) - it wouldn't function. When I turned the key there was no voltage to the starter, however, the choke would engage when I pushed in the key at the "on" position. I monetarily jumped the starter once directly to the battery just to see if it would engage and it did (plugs were out). I tried it a second time but nothing happened. In hindsight I don't recall if the red plug was connected the second time, but that shouldn't matter since I bypassed the solenoid (right?).
Tomorrow I'm bringing over a couple OEM solenoids I have in the garage that match the motor and see what happens. I'm also bringing a complete working remote with red plug and working battery leads, in addition to TWO starters (one new, one not).
Is there something else I'm missing here on the motor side I need to check? I expect that by changing out the solenoid, cables, battery, and remote that I should be able to get the starter turning. I've never had this type of problem before - and I've changed out many starters and solenoids that were bad.
I can't believe I didn't catch that the solenoid was so different - similar shape, though with four Poles (3/8" top and bottom, 2 smaller in the middle). I'm extremely curious how it was working to begin with.
