TRACKMAGNA17
Thread starter- Joined
- Mar 16, 2009
- 8
Just brought my boat out of storage. I hooked up the muffs on the motor and fired it up. water to muffs from hose was warm, but not hot by any means. It was pumping water out of the motor like normal and I let it warm up for several minutes before Idleing it up. Once it was warmed up I opened it up briefely a few times. Then a buzzer went off inside my shifter so I shut it down. After a few minutes I started it back up again and when I put it in gear and cracked the throttle again the buzzer went off. I felt the water coming out and it was warm,but not hot. The buzzer had a purple and a brown wire attached to it. Is this an engine temp alarm? If so where is the temp sensor and how do I test to see if its bad? The engine did not seem to be running extra hot cause I pulled the cover off the motor and touched each cylinder head with my hand. This alarm has never gone off before, but I've only owned this motor for two years. Also any other tests that I could do would help also.
Thanks,
Al
Thanks,
Al
