bostonwhalermontauk1965
Thread starter- Joined
- Sep 4, 2010
- 91
Hey guys....
Ive been on here asking questions about where to go from here. I pulled out my old 1982 Johnson 50 from hiding and totally re did my 1965 boston whaler from the ground up. I am really happy with how it turned out, except the motor has been very stubborn in coming back to life. Here is what I did and where Im at. For the motor alone, I put in a new water pump impeller, rebuilt the fuel pump and carburetors, and replaced fuel system including a new tank, from front to back.New line, bulb, filter and hoses with fittings.I installed a new engine side wiring harness, because the old one was corroded. I put in new plugs and wires, and the engine has 135 lbs of compression in both cylinders. I am using ethanol fuel, but it is brand new gas and hasnt had any time at all to have water accumulate yet to be the cause of my troubles I dont believe.
It develops an annoying hesitation when opening the throttle on its way up to full speed. I am also not convinced that WOT is really all this motor has to offer. I seem to remember it going a lot faster before. I am at a loss. Is there a chance that the ethanol itself is causing the motor to run like crap? and also, does anyone know how fast a 17 foot whaler should roughly be going at WOT with a 50 horse 2 cycle? Im about to bring this thing to a marine mechanic because I am starting to suspect that possibly under load I am losing ignition. By the way , I tested both ignition wires with a timing light on flywheel on idle so far, and they are firing at the right time. Also the bright blue spark will jump about 3 inches with wire off. Thank you in advance for any ideas - Paul
