1982 johnson 60hp wiring problem
Rich305
Ok I have a 1982 johnson 60hp, the problem I am having is when I turn my key to shut the motor off it dosent shut off. The control box was in working order when I took it off another motor and the ignition was working fine . It's the older model with the red plug, I went to plug the red plug in the motor and the red plug on the motor was carroded so I hard wired it and eliminated the plug. The problem I am having is finding out where the black and yellow wire go. I looked at the schematics and it shows a black and yellow wire comming from the power pack and on my power pack I see no wire comming from it that connects to the control box. If any you guys could help it would be great thanks guys
